How to attach base moulding to concrete
djh | Posted in Construction Techniques on September 13, 2006 03:40am
Hi all,
Recently installed a tongue and groove wall in a customer’s basement.  He would like base moulding installed on the new wall and two existing walls one of which is painted skim coated concrete block. Any thoughts on how to attach the moulding to the block wall (about 16′)? I’m thinking liquid nails but how does one hold the moulding tight to the wall until the adhesive cures? Any other ideas?
Thanks,
Don
  1. Junkman001 | Sep 13, 2006 03:53am | #1
    If you are using glue push up against the molding with bricks blocks cans of tomato juice etc.
    Insert initially amusing but ultimately annoying catch phrase here.
  2. Piffin | Sep 13, 2006 04:15am | #2
    buckets of heavy stuff and or springboards to opposite side of room
  3. inperfectionist | Sep 13, 2006 03:09pm | #3
    DJH,
    In addition to heavy objects and springboards, I sometimes use tapcons. After the glue dries I pull the screws and fill the holes, prime, paint, stain etc.
    H
    1. Brooks | Sep 13, 2006 04:48pm | #4
      10 minute epoxy, not Liquid Nails. I did this - works well.And NO gaps!Brooks
  4. BryanSayer | Sep 13, 2006 04:54pm | #5
    I use plastic anchors and trim screws where I have to attach trim to brick walls. It's removable, but more work than using a fast setting glue. Some of the glues are similar to contact cement. You smush the pieces together, then pull them back apart. Wait a few seconds then stick them back together.
  5. sungod | Sep 13, 2006 05:13pm | #6
    I used drywall mud. It sticks good and prys off easily. It's no good in wet areas.
    1. djh | Sep 14, 2006 02:12am | #7
      Thanks all. Customer solved the problem, doesn't want trim on the concrete walls. Whew!!
      Don
