How to clean leaf stains off of new conc
trades1 | Posted in General Discussion on November 3, 2009 09:10am
How can I clean maple leaf stains off of new concrete if the sealer was stained? I am worried about removing the sealer before winter (Northern ILL) and not being able to reseal it in time.   What will happen if I don’t have the sealer?
  1. Scott | Nov 03, 2009 11:26pm | #1
    Muriatic Acid?
  2. florida | Nov 04, 2009 12:08am | #2
    Call around to janitorial supply stores and find some phosphoric acid and use that and a pressure washer. It'll make it all look like new. If you can't find it easily pick up some Ospho rust remover and spot clean the stains.
    1. trades1 | Nov 05, 2009 03:29am | #11
      Is there any danger of damaging the sealer or concrete and will it need to be resealed.  Have you actually used this before?  Thanks
      1. florida | Nov 05, 2009 04:39am | #12
        I didn't realize you had sealer down already. The acid won't be effective on the stains that are on sealer, only on raw concrete. Any acid can damage concrete but phosphoric acid is fairly slow and mild. I've used it for 30 years, sometimes weekly on dirty concrete without problems. Muriatic acid will pit your concrete in no time. If the leaf stains are on existing sealer I'd try some trisodium phosphate(TSP) and vigorous brushing. Spic an Span has TSP if you can't find the real thing.
      2. alwaysoverbudget | Nov 05, 2009 07:17am | #13
        my front porch gets stain bad! after the leaves go away, about a month ,it's all wore off naturally.the older i get ,
        the more people tick me off
  3. junkhound | Nov 04, 2009 12:59am | #3
    THAT is called  PATINA <G>
    Let it be is my suggestion.
      Dam_inspector | Nov 04, 2009 01:16am | #4
      It's free concrete stain!
  4. mikeroop | Nov 04, 2009 05:37am | #5
    they always wear off at my house.
  5. DanH | Nov 04, 2009 06:25am | #6
    A rust remover like oxalic acid will probably do the job. (Keep it away from anything aluminum.)
    A strong nation, like a strong person, can afford to be gentle, firm, thoughtful, and restrained. It can afford to extend a helping hand to others. It's a weak nation, like a weak person, that must behave with bluster and boasting and rashness and other signs of insecurity. --Jimmy Carter
    1. Scott | Nov 04, 2009 06:45am | #8
      Oxalic does rust? I didn't know that. I've got a few projects that will now commence.Thanks,Scott.
      1. DanH | Nov 04, 2009 06:50am | #9
        It's not as strong as some other rust removers, but it does the job.
  6. JohnD1 | Nov 04, 2009 06:34am | #7
    I live in the Chicago area. The leaves, especially oak, leave big stains on the concrete. About a month later they are gone. Yours should disappear also.
  7. user-54049 | Nov 04, 2009 07:34am | #10
    How about cholrine (bleach)? Should work on an organic stain like leaves.
    Works in my plaster pool like a charm.
    Good luck
    matt
  8. 6bag | Nov 07, 2009 05:20am | #14
    don't let your new concrete go through it's first winter without sealer.  the first year is the most critical in our climate.  if you're not sure you can't reseal it, wait until the spring.  what kind of sealer did you use?
    PANIC CHAOS DISORDER.........my work is done here.
