How to cut a 61/2″ vent hole thru Hardie Plank
user-389891 | Posted in Construction Techniques on January 19, 2021 01:10pm
I am trying to find the most efficient way. The hole doesn’t have to be perfect? Would a jig saw work? I actually have Allura but I think its the same material.
I just bought the wll thimble and it looks like I will need a 6 1/2 hole.
    unclemike42 | Jan 19, 2021 02:49pm | #1
    You can smack it with a hammer if you want. (practice on a scrap length if you like)
    but this might make a nicer hole.
    https://www.lowes.com/pd/Bosch-4-in-T-shank-Carbide-Tooth-Jigsaw-Blade/50247177
    If you use a blade meant for wood or metal, it will just wear down the teeth pretty fast.
  2. qlove | Jan 19, 2021 02:59pm | #2
    If you are just making one hole you should be able to cut it with a jigsaw pretty easy. Yes, it will be hard on the teeth, so don't use a real expensive blade. I'd go with the wood blade over metal for the more aggressive teeth. My house is sheathed in hardieboard and I have cut it with sawzall (carbide demo blade) and circular saw with both the special blade and regular framing blades.
