I’ve got a new roof and siding. An old crack in foundation doesn’t seem to be leaking. I need a very good contractor or engineer that can truly find the cause of this leaking. Can I get some advice on how to find such a person? What “job title” would such a person hold? Would that person hold certain certifications? I really need help. I hope you can give be real direction.
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
Hard to give a useful answer without a lot more info than you can give in a post like this. Ask local contractors. Google locally for "wet basements" and then check references thoroughly. Problems like this can be difficult and/or expensive to fix, which can be an invitation to overcharging. Sometimes the "obvious" solution doesn't help a bit. Sometimes the solution is inside the basement, sometimes outside.
I googled ‘Building Consultants’
I clicked on one of the results and it specifically said ‘find source of water intrusion ‘ as one of his services.
Give that a shot and see what you have near you. Let me know how it turns out.
Good luck and sorry for your misfortune. I know your pain on this one.
