How to finish a WET basement?
IronHelix | Posted in Construction Techniques on August 18, 2004 10:12am
I have client that has a home with a poured basement (1950’s) that leaks on occasion….at the floor/wall intersect and at assorted places on the surface of the wall.  He wants me to assist and direct him in insulating and finishing the basement.
Gutter and landscape considerations have been addressed & corrected.
Currently the occasional water leak is readily handled by a shop vac.
I need some input on the design of the wall system to allow for water drainage, moisture evaporation and exclusion of water from the framing, insulation and wall finish.  Floor will be epoxy coated with removalable area rugs where required.
Bill (client) and I have discussed several scenarios…..BUT we would like to have some experienced persons advice, or a good article/reference  to help solidify our design.
Thanks……………..Iron Helix
  1. DanH | Aug 18, 2004 10:45pm | #1
    Some people around here have used the plastic "baseboard" drain systems, with mixed results.
    But if you have the entire basement vacant, I wonder if it wouldn't be best to simply cut it up and install tile under the floor. (At least if you can't dig down on the outside and install footing drains.)
  2. maverick | Aug 18, 2004 11:12pm | #2
    My previous house was wet any time it rained. I hammered up the floor large enough for one of those plastic sump liners (about a 2' dia.)and put a float operated pump in it. Problem solved. I never had a drop of water again. Then I went on to finish the basement.
    The liner and pump cost about $200.
    You also might want to think about a back-up power source. Lots of rain and no power would spoil the party
    rjw | Aug 18, 2004 11:55pm | #3
    Sounds like a forward pass to me: only 3 things can happen and 2 of them are bad.
    "It is as hard for the good to suspect evil, as it is for the bad to suspect good."
    -- Marcus Tullius Cicero, statesman, orator, writer (106-43 BCE)
    1. mikerooney | Aug 19, 2004 12:10am | #4
      If you don't mind, Bob, I think I'll add that one to my quiver!
        rjw | Aug 19, 2004 12:54am | #6
        That was one of the old line fpptball coaches, I forget which one ....
          RichColumbus | Aug 19, 2004 03:42am | #7
          Woody Hayes...
          The Man, The Myth (not many of the stories are myth; most are true), The Legend
          1. pvaman | Aug 19, 2004 04:21am | #8
            There was a discussion a while back (w/in 2 weeks) about basements and within that thread someone posted a site of a company (or organization) that dealt specifically with 'what's the best way to design a dry, warm basement'. They had about a 15 page whitepaper and one section dealt with retrofitting an already in place basement. It woudl eb worth the read.
            One recommendation was to cut away the floor near the interior basement wall (18" along the inside perimeter) and install gravel and a drain line and then fill it up and re-concrete. Lot of work but it may be an option.
            jonblakemore | Aug 19, 2004 05:04am | #9
            The site is building science . com.
            http://tinyurl.com/5ncpn
            Jon Blakemore
          3. IronHelix | Aug 19, 2004 12:24pm | #10
            Great resources......I'm headed to Louisville today to see what we can work out at the site.
            I'll check back in when we make some design progress.
            Keep the good stuff Rolling In.......this site continues to always amaze me!
            Thanks......Iron Helix & Bill
          4. pvaman | Aug 21, 2004 04:17am | #11
            That's the one...really good info.
          5. Chae_An | Aug 21, 2004 04:24am | #12
            Woody Hayes, the man, the myth, the legend, and the mean right hook. :)
            Guess where I went to college.
            RichColumbus | Aug 21, 2004 04:30am | #13
            Clemson maybe?  Or would it be "that school up north"?  Gotta be one of the two.
            If from Clemson... good for you.  Great school.
            If from that school up north... my sympathies. ;)
  4. Richie921 | Aug 19, 2004 12:14am | #5
    OK, I'll take a shot.  Hopefully others add to my ideas.  I'm thinking first a good concrete waterproofer on the walls and floor (ex...Dryloc, etc).  Then, how about a perimeter drain system around the perimeter of the basement dumping into a sump pit to collect any moisture that does get in.  You would frame your walls around the inside of the perimeter drain. Finally,  use a product called dry-core as a subfloor under the carpet.  It' ll keep the carpet dry even if the floor gets damp.
    Edited 8/18/2004 5:16 pm ET by RICHIE921
