How to fix a bad edge seam in honed carrara marble counter
laposada | Posted in General Discussion on February 13, 2013 01:01am
Recently installed honed carrara marble counters. Terrible edge seam. How can this be fixed?
  1. calvin | Feb 13, 2013 09:36pm | #1
    lap
    Are these 2 slabs stacked?
    1. DanH | Feb 14, 2013 07:57am | #2
      It's a thickened edge, achieved by taking the trimmings and gluing them to the bottom of the slab.  "Booking" looks good with wood but bad with marble, and there appears to be a gap near the corner.
      (My suggestion: Latex paint.)
      1. laposada | Feb 14, 2013 09:06am | #4
        Yes Dan, Do you have any suggestions how this can be fixed? A. Using heat to release the bottom added piece of marble and then not having any seam. B. adding another piece of marble to the edge to "cover the seam". Do you know if any of these approaches will work? Do you know of how this can be fixed? Thank you for your response!
  2. laposada | Feb 14, 2013 09:00am | #3
    Yes this is a stacked edge using cut pieces from the original slab to give the look of a thicker piece of marble. Sadly as you can see from the photos the edge seam is horrible and extremely noticeable. I am looking for suggestions on how this can be fixed. Basicly A. Can the bottom added piece be removed by using a heat gun causing the adhesive to release from the top piece of marble B. Can another piece of marble be added to cover the edge seam. This is honed carrara marble. Do you know how this can be fixed without removing the entire countertop. These were installed 3 weeks ago in a new build house. Thank you for any advice on how to approach this.
    1. calvin | Feb 14, 2013 08:59pm | #5
      lap
      I'm sorry, but the pictures must not do it justice.  I'll take your word for it-the seam is unacceptable.
      Who did the work?  What are they going to do to help?
  3. Hokuto | Feb 17, 2013 08:14pm | #6
    Where is this? A countertop? What are you using for edge trim elsewhere in the room? No possibility to place edge trim over it? We have tile and marble countertops in our kitchen and I installed bullnose oak trim over the edges to hide that kind of thing.
    1. DanH | Feb 17, 2013 08:26pm | #7
      Unfortunately it's got rounded corners, so wood trim won't work unless you can custom-shape the corners.
  4. alexclark512 | Feb 19, 2013 08:11am | #8
    Very nice post guys thanks for sharing.
    Fine Arts Portrait
