Good morning,
We have a 30×16 cement slab. We hired a contractor to fill in 10 holes (image #5), sand the concrete to remove the old pattern & smooth it out. Then stain the cement to look like the one pictured in this email (image #2). They brought 2 handheld sanders with batteries. Sanded as best they could, and then put one coat of Eagle Acid Stain. It came out like this. (image #1) How can we fix this?
I have attached images of before and after.
The FHB podcast crew chats about whether or not coil stock on fascia and rake trim is necessary.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
At the least, you'll need a trowled-on finish put on top, or, considering that big crack down the middle a new slab placed on top of the old one.
