How To Fix Dent In Steel Door
jimmiem | Posted in General Discussion on March 27, 2015 07:17am
I have a small dent on the inside surface of a Stanley metal exterior door.  Any suggestions on how to repair?  Thank You.
  1. cussnu2 | Mar 27, 2015 08:27pm | #1
    Same way you fix a dent in a car ....bondo
  2. DanH | Mar 27, 2015 10:25pm | #2
    Four choices:
    1. Pound it out from the other side.
    2. Use a dent puller.
    3. "Lead" it.
    4. Use auto body putty.
  3. AndyEngel | Mar 30, 2015 10:30am | #3
    I used to work in a shop where we hung steel doors. In slack times, we'd fix dented doors with Bondo and primer. Just be careful when you're leveling the Bondo not to sand through the zinc coating on the surrounding steel.
