Another basic question…
I am framing some new interior walls with 45-degree angles. What’s the best way to frame the corner studs to support the drywall on both inside and outside of the corner?
Thanks!
Thanks!
demo hammer and a wide chisel..
WOW!!! What a Ride!
The inside of the studs should be tight with each other, the outside I measure what the start point of the 45 degree angle on the plates. Usually 1-1/2 or around there then rip a stud at 45 degrees and pound it in.
What's wrong with me? I could ask you the exact same thing.
you could rip down 2x6 to make end studs with chamfered faces. Use 67.5 as the angle for your faces and it should work out fine. 22.5 is the angle for for your plates.
If I have the numbers wrong, someone will be by shortly to tell us ;-)
The difference between stupidity and genius is that genius has its limits. -Albert Einstein
http://www.peteforgovernor.com
Check out the drawing. Note how the offcut from the center 2x4 fills out the corner for solid nailing. Substitute regular lumber for the metal studs.
.View Image
Edited 8/9/2006 6:22 pm ET by RalphWicklund
Perfect! Thanks for your help.
Hey Ralph, that is really crafty, basic geometery... I like it alot!!
