How To Get Appropriate Wood Dimensions?
DavidAndersen | Posted in Construction Techniques on September 9, 2004 08:18am
For my trimming project, I will need boards in finished sizes of:
(A) 3/4 x 5 7/8
(B) 1 1/8 x 2 11/16
(C) 1 1/8 x 4 1/4
For the A boards, I’m thinking I should cut down 1×8’s to get this size.
For the B and C boards I’m not sure.  Can I find these sizes (or close) at lumber yards?  I do have limited access to a planer if that’s what I end up needing to do.
Anyone have suggestions?  Thank you.
David in Iowa
Edited 9/9/2004 1:37 pm ET by davidbear351
  1. jet | Sep 09, 2004 09:27pm | #1
    B&C can be purchased as 5/4 stock. and ripped from a 6" wide. B gives two boards each were C has wastage.
    "Sir, if you were my husband I would poison your tea"
    "Madam, if I were your husband I would drink it." Sir Winston Churchhill
    IMERC | Sep 09, 2004 09:32pm | #2
    Take  "C" out of a 5/4x10... Less waste... 2 per length...
    WOW!!!   What a Ride!
  3. DavidAndersen | Sep 10, 2004 12:22am | #3
    5/4 board is not readily available in my area (so far anyway).  I can get 5/4 x 6 cedar, but not 5/4 x 10.
    Does anyone have an opinion on using fir/pine 2x6's cut/planed down to 1 1/8 x 4 1/4 instead of cedar?  I understand that they are not as durable as the fir/pine from years ago.  Any other concerns?  I'm new at this (obviously).
    Thanks,
    David
      Sphere | Sep 10, 2004 12:30am | #4
      the biggest problem of planing down a 2x6 is all the knots, and wane.
      I'd opt for Structural select Yellow pine..like 2x12's...much less knots, and straighter'tighter grain. A 2x6 is right snotty wood for anything other than studs.  Fast grown, full of defects, contains pith, poorly sawn..etc.
      5/4 sugarpine is what ya really want to locate..sweet stuff, see if a local yard (NOT LOWES) could Special Order ya some.
      Sawmills also can hook ya up with Poplar..they may have a planer for rent by the hr.
      1. DavidAndersen | Sep 10, 2004 12:38am | #5
        Thanks Sphere. Do I also need to be concerned about a particular moisture content of the wood?  Someone has mentioned that kiln dried stuff from the lumber yard is only at 17% and that might not be good enough.
          Sphere | Sep 10, 2004 12:50am | #6
          correct, it may say Kiln dried, and it may well have been..the problem is storage after the kiln..it will reach equalibrium moisture content to it's surroundings..keep it dark and damp? It will become wetter.
          Another hazard of using a 2x6 for "millwork" is it will warp shortly after you spend time planing it flat and true (in most cases, I have got away with it tho').
          Like I said, if ya have to mill it from 2x stock...look really carefully for decent SELECT STRUCTURAL grade..you may end up really happy..
        2. Piffin | Sep 10, 2004 02:23am | #7
          It might help to know what your area is. The fact that only 5/4 cedar is available easily suggests that cedar is the prefered choice with the local folks and that may be for a good reason.
          I don't know about these other guys recommending 5/4, but if I order 5/4,I get stock that measures 15/16"
          If I wanted finished stock at 1-1/8", I would ned to order 6/4 and plane it down, or buy rough cut 5/4 and plane one side only.
            Sphere | Sep 10, 2004 02:35am | #8
            yer getting the short end there Piffen
            5/4S4S should be 1  1/16 MIN. 1 1/8 Max.
            Rough can be almost anything from true 1 1/4 on up to 1 3/8
            At least thats been my experiances in many places.
          2. Piffin | Sep 10, 2004 03:35am | #9
            I've never seen a 5/4 S4S that finished more than 1-1/16"
            Maybwe they plane too soon and I see shrinkage up here.
            RichColumbus | Sep 10, 2004 03:43am | #10
            >>I see shrinkage up here<<
            Did you REALLY mean to say that?  LOL
          4. jet | Sep 10, 2004 03:44am | #12
            Great minds think alike or fools seldom differ
            JINKS!!!   you owe me a beer!
            Edited 9/9/2004 8:45 pm ET by Jet
          5. Piffin | Sep 10, 2004 03:54am | #13
            keep in context - I never said I see shrinkage down there.
            RichColumbus | Sep 10, 2004 04:00am | #15
            Yes... down here, there is rarely shrinkage.  We take some pride in ours not shrinking.  We do occasionally get some "old growth"... but rarely "shrinkage" !!
          7. Piffin | Sep 10, 2004 04:07am | #18
            Forget my statement about keeping in context. I jsut realized the title of this thread ahs tp do with measuring the wood.
          8. jet | Sep 10, 2004 03:43am | #11
            Do we really want to go there???????"Sir, if you were my husband I would poison your tea"
          9. DavidAndersen | Sep 10, 2004 03:56am | #14
            Piffin -
            I'm in East-central Iowa.  Not particularly rainy, not particularly dry.  If anything, I suspect the lack of readily available variety in 5/4 wood (many places tell me they can order about anything) has to do with the nature of the housing market.  Probably aren't as many high-end homes built here as on the coasts, plus we are a long way from the nation's biggest lumber stocks.  That's my guess anyway.
            David
          10. Piffin | Sep 10, 2004 04:05am | #16
            not that many lumber lills in Iowa though
          11. DavidAndersen | Sep 10, 2004 04:06am | #17
            That too!
          12. User avater
            BillHartmann | Sep 10, 2004 04:52am | #19
            Here are a couple
            http://www.woodfinder.com/listings/010863.php
            http://www.woodfinder.com/listings/008061.php
            Go to http://www.woodfinder.com and inter your zip code.
            http://phonebook.superpages.com/yellowpages/C-Sawmills/S-/T-/ Enter you city and state.
            And here is a list of 66 sawmills in Iowa
            http://www.ag.iastate.edu/departments/forestry/ext/pubs/F-301.pdf
          13. ClaysWorld | Sep 11, 2004 10:18pm | #20
            Nice job in the info department.
          14. DavidAndersen | Sep 12, 2004 09:54pm | #21
            Thanks Bill.
