To prevent moisture buildup and improve performance, install a continuous air barrier—such as drywall or specialized membranes—under tongue-and-groove boards or other interior wall paneling.
I typically use 2" nails. Sometimes longer, sometimes a bit shorter. Depends on the trim and what you have to nail through to get to the framing.
Just use Liquid Nails? With just Liquid Nails, the trim may sag or creep...or even fall down...before the adhesive cures. Consider using a few nails to tack it up while the adhesive cures.
Very often I'll use both. I always nail, but I'll also use an adhesive to also hold the trim to the ceiling.
If you want to omit nails alltogether, FHB just had an adhesive article in the last issue. Look at the high-end hot-melt glues. I'm tempted, especially for multiple piece built-up trim that is stain-grade...lots of returns, etc. Somewhat expensive setup, but it'll pay you back over time. Hot melt will give virtually instant hold vs the slow cure of a curing adhesive.
Edit: Came up with this FHB link in a search:
http://www.taunton.com/finehomebuilding/pages/h00004.asp
Edited 12/1/2003 9:52:32 AM ET by Mongo
Do I use nails, Yes
if so, what type? That would depend on the size and application of the moulding. A common crown moulding (2 1/2") installed in a typical setting (interior wall to ceiling, sheetrock over wood frame) will require finish nails. 1 1/2" nails along the bottom of moulding into wall studs, 2 1/2" - 3" angled up into wall plates and/or ceiling joists.
Can I use liquid nails instead? Not instead, but along with can`t hurt....especially in areas where framing is hard to find.
Based on the generality of your questions and the apparent lack of prior experience, I`d suggest you do a little research on the subject as installing crown moulding is not one of the simpler tasks as far as trimwork goes. FHB has had several good articles in the past.
J. D. Reynolds
Home Improvements
"DO IT RIGHT, DO IT ONCE"
