how to install laminate on conc backer board?
greenpancakes | Posted in Construction Techniques on April 17, 2010 06:11am
As the finishing touch at the top of the shower I want to install a laminate  barrier above the tub surround. should I skim coat the ruff durock with thinset or something to have  a smoother surface for the contact adhesive. Or seal it with some primer?
  1. oldhand | Apr 17, 2010 07:30pm | #1
    Are you talking about plastic laminate? I don't know how the expanion/contraction rates compare with the 2 materials,maybe someone will be along wth that info.
    Possibly construction adhesive would work.  When I put p-lam on drywall i usually go with yellow pva. The substrate and lam expand and contract at enough different rates that contact cement is no advantage. Point is ceilings and walls can have a different standard over a countertop.
  2. KenHill3 | Apr 17, 2010 07:59pm | #2
    I would use concrete bonder,
    I would use concrete bonder,  rolled on. Maybe two coats to get it smooth enough.
    http://media.doitbest.com/products/278742.gif
