Thought I would share my method of fabricating a curved molding.
On occasion a client will need a curved shoe molding for a remodel project. In most cases the curved starting riser is anything but a perfect circle. That said I usually request the customer provide us with a full-scale template outlining the curve as it will be used in its final application. Photo 1 shows a customer provided paper template. Note the off round nature of the curve.
With a full-scale template it’s a simple matter to trace the outline on a section of ¾ plywood and cut the profile on the band saw.
Once the wood pattern is cut I drill a series of 1-1/2 inch holes around the perimeter of the curve. The holes allow me to use spring clamps to force the laminates against the form.
The curved pattern, along with the remaining straight tail is now screwed to the shop floor.
<!----><!----><!----><!----><!----><!----><!---->Once the bending jig has been fastened to the floor I measure out the length of the laminates. This molding has a finished profile dimension of 5/8 x 3/4 and 80 inches long including the length waste factor. This is a fairly tight radius so I opted for 8 plies of .08 thick red oak. Spring back is always a concern; eight ply’s works well for this application, harder wood such as maple may require 10 plies. Prior to ripping the stock I mark a “V†reference line on one edge enabling me to re-stack the laminates in the same order for the best possible grain match.
Once the laminates are sized and the edges de-fuzzed I stack the strips in the proper order and proceed to apply the glue. For stressed laminations my first choice of adhesives is Unibond 800, a powder catalyst resin based glue. Mixed at a ratio of 1 part catalyst to ten parts resin gives me about 45 minutes open time. I apply a thin uniform coat to both faces of the joint. The glue spreader is nothing more than a section of paint pad cut to size and tacked to a small wood block Cheap, fast and does the job nicely
Once all the strips have been coated I wrap the entire bundle with stretch wrap. Stretch wrap is pretty indispensable in lamination work. It has the unique ability to keep all the plies in line yet still allow for individual longitudinal slippage as the stack is bent around the form.
I’ll start on the tight end of the bend, clamping the wood to the form with one pony clamp. This is a simple bend so I work the long end of the laminate with my left hand while applying spring clamps into the fixture holes with the other hand.
An assortment of clamps are used to complete the operation
I try to time the gluing procedure so the glue has time to set up over night. Once the clamps are removed you can see how little spring back there is, about an 1/8 inch on the open end of the bend. The small amount can easily be pulled into place during the install.
Notice how the stretch wrap contains the glue. No big drips and globs of hardened clue to contend with during machining operations.
A wide belt sander makes quick work of truing up the faces of the molding. A belt sander or angle grinder fitted with a sanding disk would also do the job.
I use a trim router to mill the round over. Note the stabilizer block attached to the underside of the router.
A drill press mounted pneumatic drum sander cleans up the remaining tool marks and preps the surface for finishing.
There you have it, a shepherds cane worthy of Little Miss Bo Peep. In real time, not counting the glue drying, this project took about two hours.
Thanks, great series. I gotta get some of that wrap.
That's some mighty fine homebuilding right there, Riverman. Great technique (and nice photo essay, too). Thanks.Remodeling contractor who once visited the Glass City.
Thanks for the lesson. That plastic wrap trick is very cool; I'll be using that for certain.Bill
Hey Armin,
One more for the hit parade.
thanks.A great place for Information, Comraderie, and a sucker punch.
http://www.quittintime.com/
Thank you.
That's why I enjoy this site and these threads so much. The photo presentation makes me feel as though I am watching over your shoulder. ...The unspoken word is capital. We can invest it or we can squander it. -Mark Twain...
Be kind to your children....they will choose your nursing home.
...aim low boys, they're ridin' shetland ponies !!
The plastic wrap is a great idea! Never heard that one before, but makes a great deal of sense.
Great pictures.
Armin - thanks for posting that. Very Kewl.
http://grantlogan.net/
Thanks for the effort in posting this educational series you are what fine homebuilding is all about. How would you make the riser that goes with that shoe moulding?
Thanks for the education
Greg in Rainy Connecticut
"How would you make the riser that goes with that shoe moulding?"Check out my thread in the photo section titled Birch Iron & Rustic Maple staircase post #12 April 4.Edited 4/17/2007 8:21 pm ET by riverman
Edited 4/17/2007 8:22 pm ET by riverman
Thanks one and all I'm glad you found it informative.
