I have primed corregated cement siding that I want to paint to match original color which is a black color in the deep recesses and a redwood color for the top. I assume I would paint the whole siding the base color black. I’ve tried various techniques to paint the highlighted portions but everything I’ve tried soaks into the vissures. Suggestions?
![](https://images.finehomebuilding.com/app/uploads/2024/07/16103615/01232548-cost-of-building-house-feature-thumb-16x9.jpg)
Understand the difference between estimating and cost planning, and don't let your sweat equity evaporate into budgeting mistakes.
What is the product you're using?
Allura tile
Allura tile.
Edited 5/21/24:
If you have some to experiment with, I'd suggest the reverse of what you described.
Paint with the red first and allow it to fully dry, then quickly paint the black focusing on the 'fissures' and then wipe it off with a clean rag wrapped over a stiff sponge. Maybe dampen the rag with whatever the paint manufacturer recommends for cleanup.
Thanks. Novel solution.
Updated my comment.
