how to prep OSB subfloor for vinyl plank flooring
user-6891949 | Posted in Construction Techniques on July 12, 2018 11:36am
I have OSB subfloor that is not flat (eg in one corner of a room the subfloor drops 1/4 inch over 2 feet). I want to install vinyl plank flooring but I need to make the subfloor flat first. I will probably install a 1/4 inch sureply underlayment first. Even to install the underlayment, my subfloor needs to be flat. How would you do that? Sanding down the high spots? (this would weaken the subfloor though). Using a leveler? (most leveling compounds should not be used on OSB, as it is not a good substrate)
    sawdust_steve | Jul 13, 2018 01:10pm | #1
    Use a primer on the OSB then use a self leveling compound.
Pressure Washing Made Portable
This electric pressure washer is compact, lightweight, and easy to maneuver.
