Upgrading the footings and columns that support a girder beam is an opportunity to level out the floor above.
How to Install Cable Rail Around Wood-Post CornersRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
There have been a number of threads which discussed this, so a search should turn up something useful. Some of the options include gluing multiple layers of plywood before nailing the flooring, and installing a floating floor. It's not recommended to directly glue solid wood flooring be/c the RFH temps will cause a lot of movement and gaps in the flooring. I've directly glued bamboo, which is laminated and so has a bit more stability, and it's survived the first heating season thus far without a problem.
*Is the gypcrete floor already installed or are you planning this project?? If you're in the planning stage, you can use sleepers spaced at whatever the nailing requirements are for your hardwood flooring. The gypcrete (or lightweight concrete) is poured between the sleepers.
*Eddie, Here's a little ditty that may help you out..it even has pictures:http://www.jlconline.com/jlc/archive/energy/radiant_sept99/page3.html
