How to repair minor scratches in polished limestone tile?
doitall | Posted in Construction Techniques on January 7, 2010 06:49am
I need some help! I have a polished limestone tile floor (12″ x 12″ tiles). On a couple of the tiles, an abrasive scrubby pad was used to remove some residual grout (by yours truly). Not deep scratches, and not a large area (maybe 3″ x 3″ on adjacent tiles), but you can see the scratches. Am I out of luck (do I have to live with my stupidity), or is there a way to polish these back up? As always, every bit of advice is greatly appreciated. Thank you. DIA
    Matt | Jan 07, 2010 08:26pm | #1
    I haven't tried this on
    I haven't tried this on "polished limestone tile floor " but I'd try white polishing compound from the auto parts store. It only costs a coupla three bucks and is one of the more gentler polishs. I've used on stuff like counter tops, bath tubs, etc.
  2. cic317 | Jan 15, 2010 07:53am | #2
    you can try using some grout. mix it just as you would normally & just rub the areas were the scratches are. Has mild abrasives in it so it should polish out the scratch. The tile may have been sealed since Limestone is porous & it may have to be resealed
Mortar for Old Masonry
