How to safely cut into a black steel gas pipe line?
Tripwire | Posted in General Discussion on October 26, 2012 08:11am
I have an existing pressurized gas line under my house. I want to cut that line to my fireplace, so i can change it from LPG to NPG line which i recently had installed by the utility company.
I need to cut out a three ft section, unscrew the pipe ends and cap and connect to the new source…..
How can i cut the existing line safely?  Of course i will shut off the gas and let the water heater pilot burn off what it can
yes i have a permit for it and the work will be inspected
thanks!!!!!!!
  1. florida | Oct 27, 2012 11:00am | #1
    Use a pipe cutter instead of a saw.
    1. Tripwire | Oct 27, 2012 07:59pm | #2
      Ah, yes but that would involve buying a tool that i will never need again .....
      Any other options?
      Steve
      1. DanH | Oct 27, 2012 11:57pm | #3
        Any other options?
        Rent a pipe cutter.
        But in theory the hazard is that combustable vapors will be released as the pipe is heated.  So you could either heat the pipe and vent off the vapors before cutting or somehow keep the pipe cool while cutting.  Hard to say how much of either is enough, though (or even how serious the hazard is to begin with).
        Another option is to fill the pipe with nitrogen or CO2.
        1. DanH | Oct 28, 2012 08:46am | #5
          Also note that the hazard is from an explosion in a "relatively" tightly sealed enclosure.  If there is a way to vent the pipe (eg, uncouple a union or remove a plug) within a few feet and also vent or disconnect (via valve or coupling) the rest of the pipe then the worst you'd get is a "pop".  And, of course, vent the area where you're working -- windows open, fan running.
  2. junkhound | Oct 28, 2012 12:34am | #4
    Fill the pipe with water and cut it any which way you have available.
    Was going to suggest about 10 other ways, but since you do not even have a pipe cutter, doubt you have a N2 or CO2 bottle or even an air compressor or shop vac or vacuum pump?
    BTW, WHY do you think you would never use a pipe cutter again, that is the easy way to go.  A HF cutter is < $10.
