how to strip heavy clear coating off of a slab table
Is there a way to chemically strip the heavy clear, plastic like coating off a wooden slab table? Thanks.
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
Belt sander.
But you can try a few different paint removers and solvents. Nothing will work if it's an epoxy bar topping, though.
Belt Sander?
Belt sander? My gosh, that's like using an axe to cut fish fillets. If any sander, it should be rotary. But the type of finish wasn't mentioned. If possible, I'd always start chemical before mechanical.
"heavy, clear, plastic-like".
I Get You
But some chemical finish removers can remove the finish without taking off layers of "patina." I still don't understand the concept of a belt sander on a table. You just must be a Picasso with it. Trim your shrubs with a chain saw?
No, I use one of these: http://tinyurl.com/6a3feft
I'd rather trim shrubbs with a biGURL than a tinyurl
