How to to frame a barrier free shower ?
user-7509431 | Posted in General Discussion on April 20, 2020 01:22am
I am remodeling and repairing a water and termite damaged restroom, replacing old post and pier, girder and joists.
I would like to replace shower with a barrier free shower, don’t know the details for framing shower floor
how much to notch the joists
searching for a detailed article ? Any help would be appreciated
Thank you
Joel
  1. jlyda | Apr 20, 2020 06:18am | #1
    Depends on the shower base you plan on using. If you are hiring the tile out, ask your tile guy what he’s going to do for the base. If you are doing it, plan out what you are doing for your base and make sure floor is constructed to accommodate. There are so many options you really need to pick one and go with that. Sometimes with linear drain you don’t really have to bring floor down to accommodate, but again all has to be planned ahead of time.
  2. florida | Apr 20, 2020 10:13am | #2
    You would need to drop your joists down far enough to get at least a 2" thick pitched slab on top of the sheathing.
  3. user-7509431 | Apr 20, 2020 10:47pm | #3
    I was leaning towards a mud base or Schluter System base ?
  4. jlyda | Apr 21, 2020 01:31am | #4
    If a mud base you definitely need to drop the floor. Depending upon length of your pitch you may need to go deeper than 2”.
    With Schluter preformed shower board you may not technically need to drop down floor at all. The thinnest sloped board goes all the way down to 3/16” thick on low pitch side. You will probably need to incorporate a linear drain to do this and have it installed at shower door (or door) if building entire bath floor as shower pan. I’ve attached a pic and you can also refer to Fine Homebuilding issue 255, they describe the process there. If no linear drain is being used and you want to slope away from door you will need to drop the floor some. To determine that dimension check your lengths and determine the thickness of Schulter board required to achieve your slope.
    Give Hydroban a good look. I‘ve used the Schluter system a couple times, but once I tried Hydroban never went back. I find it easier/quicker to install. It’s approved for outdoor swimming pools, so holds up well. Have had no problems at all. All my tile guys use it as well, they turned me on to the stuff initially.
    Flood test before you install tile. I’ve actually never had a leak, but if you do it will be a major pain to fix after tile is installed.
  5. user-7509431 | Apr 21, 2020 09:58pm | #5
    WOW !
    Excellent explanation, I understand
    Thanks to everyone
    Joel
