how to vent a woodburning stove
cutawooda | Posted in General Discussion on September 26, 2010 01:12am
Recently obtained a used Atlanta Stove. Got it for free, (if I bought the house).  So it cost me $52, 800 for the stove.
I figured I coudl use it in carpentry shop and now I need to know the best way to vent it.  Very unfamiliar with vent pipe and such but I heard from the guy I purchased the house from that it is a very good wood burning stove. I currently use a kerosene torpedo heater and it does work good but $$$$ to run it.
The outlet is a 6″ hole that comes out of the back of the Stove. I want to avoid cutting a hole in my roof of my shop. It is metal and I just dont want to cut a hole in my roof. I have a thick wall to my shop since I built wood framed wall over the red iron framing. I believe it is about 14 inches thick frominside to outside finished. I have OSB walls on the inside  and yes the shop is insulated directly under the metal exterior.
Shop height is 12 sidewalls.
My confusion comes from double wall or not, Black flu pipe or not. Clearances, especial coming through the osb walls. Proper hieght above shop, joint connection and such.
Can some one guide me the right way please.
thanks
  1. DanH | Sep 26, 2010 01:21pm | #1
    First off, check with your local BI about local regulations.  They trump any advice you'll get off the internet.
  2. cutawooda | Sep 26, 2010 01:56pm | #2
    clarification pics.I wanna flu to the left of the window
    1. joncro55 | Oct 26, 2010 04:19pm | #12
      Did a similar project before....
      Make sure that you cover the flu properly from the outside of the house.
      I used some heavy wire mesh, this way when the smoke is not going out of this opening in the side of your house, the squirrels, rats, birds, and mice arent climbing in the other side.
      Check these guys for a good price and fast shipping, I shopped around and this is who I used.
      http://www.bwire.com/
      Good Luck.
    2. Piffin | Oct 27, 2010 04:20pm | #13
      That is a decent stove you have. It appears to be a Taiwan  made cast iron with relief profile designed to increase surface area that is in contact with convection air moving over the surface.
      The exhaust is in the rear so here is how I would install it.
      place it so that it is 36" from the combustible wall surface.
      Run a single wall haevy black 6" stovepipe horizontally to the wall. Install that with a damper in it.
      Run thru the wall with a wall thimble.
      Outside you go to the insulated pipe, either triple wall "zero-clearance" or solid pak Metalsbesos type, with SS lining.
      I would do a cleanout T first out from the wall, then verticle to 3' above the roof , at least.
      Most stovepipe companies market a kit with the wall thimble, cleanout T, wall brakets, support platform, and 14' of pipe.
      I have installed a few hundrd of these
  3. cutawooda | Sep 26, 2010 01:56pm | #3
    1. cutawooda | Sep 26, 2010 01:58pm | #4
      bad pic
    2. davidmeiland | Sep 26, 2010 03:19pm | #5
      You can do that...
      ... and it might be a little ugly, but so what.
      I like Selkirk's Metalbestos UT insulated pipe. http://www.selkirkcorp.com/Metalbest/Product.aspx?id=208
      Get the proper stove adapter. Go vertical for several feet with single wall and then convert to UT and go thru the wall. Use a tee stand outside and go up past your roof edge at least two feet. Around here you have to be two feet above anything within ten feet.
      Dan is right, check with your BI for particulars, but what you want to do is very common. One thing you want to ask about is whether you need a stove with an outside air intake, but my guess is no since you're talking about a workshop.
      1. calvin | Sep 26, 2010 03:59pm | #6
        I would think he could hold single till the wall thimble, no?
        The ceiling thimble I used made up the connection from single to insulated.
        To the OP, you'll definitely need insulated outside as your flue temp needs to stay high to vent properly.  Go up at least 2 ft within 10ft especially if that slope is in the prevailing wind direction-the swirl even on a low slope creates a "dead" area for proper venting.
      2. DanH | Sep 26, 2010 04:56pm | #7
        An important detail to check is clearances and the posible need of a fire shield on the wall.  The OP should get the mfgr's specs on clearances for the stove, and if necessary be prepared to line the walls (and floor) with fireproof materials.  (In our neck of the woods even a concrete floor isn't officially "fireproof", so you need some sort of fire shield under the stove.)
        1. Scott | Sep 26, 2010 06:13pm | #8
          Check on roof clearances too. Around here the triple-wall insulated chimney pipe needs to project 3' higher than any roof surface within a 10' radius.
    MarkH | Sep 27, 2010 06:49am | #9
    I'd add a damper in the flue pipe if the stove doesn't have one.
  5. Clewless1 | Sep 27, 2010 09:06am | #10
    I agree w/ Dan ... check with the building official. You have clearance of the stove and the flue. The flue will need to be the triple wall type through your construction. You may not be able to put it too close to the window, either. Be smart ... go to the building department and get a permit and a list of your limitations/requirements. You want to be legal and safe. You jerry rig it and you risk losing out if the shop burns down in a fire (i.e. insurance may not pay).
  6. rdesigns | Sep 27, 2010 10:21am | #11
    As others have said, local bldg dept regulations will trump anything we say here, but, in general, the inspector will tell you that when you use a listed, tested product like Metalbestos or Simpson, you--and he-- will follow the manufacturer's instructions. (And, to complicate things, the instructions will also tell you that local codes take precedence over their instructions--they do this because they know that sometimes local requirements will be laid on.)
    According to your description, you will also need to be careful using single-wall for the inside portion of the flue where it turns horizontal to go thru the wall--that horizontal part can't be too close to the ceiling. The flue manufacturer will probably have a diagram that illustrates just how to do it, along with details of how to penetrate the combustible wall.
Mortar for Old Masonry
