How to Winterize a House?
freematt | Posted in General Discussion on September 26, 2006 06:19am
Hi all! I need to shut down a summer house, and another house that’s a foreclosure, for the Wisconsin winter. At some of the houses around here I have seen plumbers take apart every faucet, tub & shower valve and toilet tank valve. Others suggest that simply opening the valves and a low point and letting everything drain back is sufficient. That’s in addition to draining, water heaters, pressure tanks (for well water systems), meters and putting anti-freeze in the traps and toilets. The foreclosure has a dishwasher; what to do with that? Turn off the gas or electric to the water heater too. Anything else? — Matt
There are a thousand hacking at the branches of evil to one who is striking at the root. — Henry David Thoreau
    AaronRosenthal | Sep 26, 2006 07:19am | #1
    I think there were a fair number of posts about winterizing. Try doing an advanced search.
    Quality repairs for your home.
    AaronR Construction
    Vancouver, Canada
  2. gb93433 | Sep 26, 2006 07:38am | #2
    People I know use compressed air to rid the lines of water and then pour anti freeze down the traps. Some I know have used window washer fluid. I am not sure how well that would work in WI.
