how wide can wood bookshelf be without s
bplaut | Posted in General Discussion on March 13, 2006 11:45am
I am building a set of bookshelves out of 3/4 Mahogony plywood.    They will be 90″ high with a fixed center shelf.   Rest of shelves will be adjustable.
I am planning to put a 1/2″ by 1″ Mahogony edging nailed and glued to front edge of each shelf.     How wide can I make the shelf without risk of sagging under the weight of books?   This will be used in a library so will be mostly full of books.
I’d like to go at least 30″ wide.   If above will not support without sagging, any other suggestions?
    Ricks503 | Mar 13, 2006 11:58pm | #1
    30" should be ok.  Options to increase success are to add another solid wood strip along the back, make the strip 1 1/2" - 2", add a line of adjustment holes doun the middle of the back of the cabinet and add a 5th support pin there.
    1 - measure the board twice, 2 - cut it once, 3 - measure the space where it is supposed to go        4 - get a new board and go back to step 1
    JDRHI | Mar 13, 2006 11:59pm | #2
    3/4" plywood will do 30" no problem. Once you close in on 36" you'll be pushing it, unless the books are paperbacks.
    If you kick the solid edging up to 3/4", it will help stiffen the shelves.....especially if you rabbet the back edge when joining.
    J. D. Reynolds
    Home Improvements
  3. stinger | Mar 14, 2006 12:07am | #3
    Here ya go.  http://www.woodbin.com/ref/furniture/shelves.htm
    1. bplaut | Mar 14, 2006 04:32pm | #9
      Thanks to all of you who posted replies.   This gives me what exactly what I need!
    jonblakemore | Mar 14, 2006 12:24am | #4
    Try this
    Jon Blakemore
      EricPaulson | Mar 14, 2006 03:34am | #5
      17 minutes apart. Not bad.
      Gene, your offerings to BT have increased noticeably sinced you finished the house!
      E[email protected]
        jonblakemore | Mar 14, 2006 05:49am | #6
        huh?
          EricPaulson | Mar 14, 2006 07:49am | #7
          You and Stinger (Gene) posted the exact same link.[email protected]
            jonblakemore | Mar 14, 2006 04:19pm | #8
            I must be missing something because Gene posted:
            http://www.woodbin.com/ref/furniture/shelves.htmand I posted:
            http://www.woodbin.com/calcs/sagulator.htmAre you saying that when you click on the links the exact same page comes up both times?
            EricPaulson | Mar 15, 2006 12:17am | #10
            Oh, now it looks different. Same website though.[email protected]
            Nuke | Mar 15, 2006 02:54pm | #11
            Is this an anti-Knots kind of post? :)
