I am building a very air tight ICF (Insulated Concrete Form) house and would like to install a HRV. Will be heating with radiant floor heat so there will be no duct work for a forced air furance to run the HRV through. Do I just piece together metal ducts/flex ducts/or is it possible to use schedule 20 PVC? What size would be correct? Any recommendations on where to look for information on the topic? Thanks
Listeners write in about continuing education, minisplit heat pumps, compact home shops, and building science.
Thanks for you comments Fred. I was thinking about putting a blower door on after construction. I did get John Bower's book, but it was a bit over my head. Maybe I'll have to go back and re-read it. Have you ever seen anyone use PVC for duct work? Saw the article in FHB where it showed PVC being used to duct a bathroom fan. Wondering if anyone has used it to duct multi-baths plumbed back to a HRV?
I would not consider having all the fresh air in my house travel through pvc pipe and pick up whatever it is off gassing, but I live with an enviromentally sensitive person who is affected by minute amounts of plastic smells.
