Humidity mystery
asheville47 | Posted in General Discussion on September 6, 2020 03:42pm
I’m living in a house that developed a huge mildew problem late in the summer. Like, mildew on literally everything, throughout the living space. In addition to running the air conditioner on dehumidify mode, using damp-rid containers, cleaning, and running a fan constantly, I got a hygrometer to see what the humidity is doing inside the house. What I found is that basically the house ends up whatever humidity it is outside, even with the AC running. I’ll go to bed with the house at 55% and wake up to it 70%, AC running the whole time. The AC has been cleaned and checked so it’s not the problem. The house doesn’t seem super drafty either. Could this be caused by a lack of vapor barrier in the walls? The humidity swings are so large and relatively quick that I’m confused as to where the moisture is coming from. Has anyone dealt with this before?
  1. Hvac1 | Sep 06, 2020 07:43pm | #1
    Been in the house for a number of years and the problem just now developed? House have a crawl space?
  2. hridyard | Sep 06, 2020 08:22pm | #2
    Most of your humidity probably comes from your basement or crawlspace if you have one. A dehumidifier would be much more efficient at removing moisture from a house than an air conditioner .
    tfarwell | Sep 06, 2020 09:41pm | #3
    I'd check to see if you have water leaking anywhere. Turn off everything and check the water meter.
Grout-Free Shower Panels
