humidity probs
andyfew322 | Posted in General Discussion on June 7, 2008 04:41am
will tools in a garage in MA have issues with rusting because of moisture/ humdity?
there’s no need to reinvent the wrench
  1. rlrefalo | Jun 07, 2008 04:51am | #1
    It has to do with dew point. Tools in unconditioned spaces will always rust. Cool nights and the tools get cool. Humid days and the condensation forms on the tools. It helps to keep them covered.
    1. andyfew322 | Jun 07, 2008 04:57am | #2
      would felt be a good covering? can the cover just be draped over the machine, or does it have to  be in contact with the metal
      there's no need to reinvent the wrench
      Edited 6/6/2008 9:59 pm ET by andyfew322
      1. rlrefalo | Jun 07, 2008 05:34am | #3
        I've used horse coolers for a table saw. That worked ok. I think felt would would be good. Just draped over the machine is good.
        Rich
        Edited 6/6/2008 10:35 pm ET by rlrefalo
      2. DougU | Jun 07, 2008 05:37am | #4
        Another thing on the table saw, keep it waxed, any wax, car wax, furniture wax.........it also helps the wood slide better.
        1. andyfew322 | Jun 07, 2008 06:22am | #5
          That was my other question, I have the Ryobi BTS 1500 and It has a black top on it, is this paint or a type of metal, will it rust?
          Silence is golden, but ducktape is silver
          1. DougU | Jun 07, 2008 06:25am | #6
            That black paint(not sure if its really paint but probably) will not rust but eventually as you use the saw that paint will wear away, the wax will help slow down that wear. I would wax over the paint.
          2. andyfew322 | Jun 07, 2008 06:26am | #7
            wax then buff, correct?
          3. Henley | Jun 07, 2008 02:13pm | #8
            One thing to keep in mind, don't leave metal covered in plastic for
            periods of time.
            It will rust.
            Cloth is much safer, that's why car covers breath.
          4. DougU | Jun 07, 2008 04:56pm | #9
            Yes, buff. Makes it slick and hard.
      3. Piffin | Jun 07, 2008 05:29pm | #11
        I don't think felt is a good idea - not around here anyways. It can absorb moisture and hold it too the metal increasing the chances of rust. Same with dust, sawdust, and lint. When I see rust on tool surfaces ( not mine) that have been unused for a long time it is always worst where dust is accumulated. if you choose to use covers use something like a tableclothe for picnic tables with the plastic surface and sift backing
        1. fingersandtoes | Jun 07, 2008 06:59pm | #12
          I would have thought you would have problems with the salt air. My tools don't seem to rust, but the door knob and light on the shed they are went bad quickly.
          1. Piffin | Jun 07, 2008 07:53pm | #13
            Lot of people who are close to the water and don't tend to their tools do have fast growth of surface rust. I use the sprays I mentioned and never a problem - unless rain fills a tool box and I don't know it -
  2. Piffin | Jun 07, 2008 05:25pm | #10
    Not if you take care of them.
    Boeshield is a spray on wax that penetrates metal surfaces and works a log time. Developed by Boing for aircraft.
    SlipIt is another.
    Surfaces like TS tops get the Slipit or a paste wax automobile wax
  3. Scott | Jun 08, 2008 09:15am | #14
    I use lots of the old fashioned Johnson's floor wax for this purpose. I like it because it creates a moisture proof coating, is a lubricant, but once it's dry it doesn't load up with grime the way grease does. Dirt-laden grease is worse than no grease at all in some cases.
    Scott
    Always remember those first immortal words that Adam said to Eve, “You’d better stand back, I don’t know how big this thing’s going to get.”
