HVLP – conversion gun – which one?
toolbear | Posted in Tools for Home Building on March 10, 2009 06:59am
After painting two drive and two ped gates the way Da Vinci would, I need to entice the boss into an HVLP conversion gun.
Which do you like, which do you hate?
The ToolBear
“You can’t save the Earth unless you are willing to make other people sacrifice.” Dogbert
  1. migraine | Mar 10, 2009 07:13am | #1
    Binks has some that will use lower CFM compressors.
    Accuspray has some good HVLP stuff with self contained units including a small compressor for using a pressure pot.  I have one.  I still have a hard time getting used to the huge air hose.  What an armshoulder/ killer.
    I still prefer airless or a conventional pressure pot with a HVLP gun.
    1. toolbear | Mar 11, 2009 05:32am | #6
      Binks has some that will use lower CFM compressors. @@@Understand they are a high end brand. I will check them out. We are occasional users. Last fence we put up was in Nov. Be nice to get it all painted in the shop.The ToolBear
      "You can't save the Earth unless you are willing to make other people sacrifice." Dogbert
    Sphere | Mar 10, 2009 03:02pm | #2
    Get a turbine, the conversion guns are compressor killers, need water separaters, and are less portable.
    A turbine warms the flow of air, chases moisture out, makes WB finish flow better, can be quieter, and extremly portable.
    Yeah, they cost more, but worth it.
    1. toolbear | Mar 11, 2009 05:29am | #5
      A turbine warms the flow of air, chases moisture out, makes WB finish flow better, can be quieter, and extremly portable.Yeah, they cost more, but worth it.@@@I don't think Der Boss will go for more. I did not see any mention of oil/water filters, but looking at what comes out of my compressor, I wonder if I need one.The ToolBear
  3. rasher | Mar 10, 2009 06:39pm | #3
    To answer your question, I have the Wagner gun sold at gleempaint.com. The link to it is here:
    http://www.gleempaint.com/hvcongunnew.html
    I love it. I use it with my Makita MAK700 compressor and although the compressor runs near constantly, it seems to do OK for the occasional use that I need.
    I recently bought the #4 projector set to throw a little thicker paint and it was a good purchase for me.
    All in all, I ended up with a spray rig that paints my trim faster and better than I could do with a brush for $200 or so.
    Cleanup is quicker than cleaning a brush.
    1. toolbear | Mar 11, 2009 05:26am | #4
      http://www.gleempaint.com/hvcongunnew.html@@@ Tnx. I have the Gleem review and FAQ and downloaded the Wagner manual. For occasional use, it seems to worth a look. I figured that with a pot, all the bits go into a can of solvent. I like the idea of not having 50-100' of hose filled with enamel. Am I right?The ToolBear
  4. holy hammer | Mar 11, 2009 05:44am | #7
    Just bought an Earlex 5000 HVLP. Love it. Try sears.com $300.00
    Constructing in metric...
    every inch of the way.
    1. toolbear | Mar 11, 2009 11:31am | #8
      Just bought an Earlex 5000 HVLP. Love it. Try sears.com $300.00@@@Googling as we speak. Tnx.The ToolBear
