I’m looking for decent HVLP sprayer and wondered if you have any experience with the FUJI shown in Woodworker’s Supply. I’ll be spraying latex on trim and cabinets so the Q4 at $700 is probably the way to go. I also considered a CAPSPRAY but it’s a bit pricey for my occasional use.
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Hi dave,
I had the same problem. Ive a Graco, a Titan, and an Apollo. The Titan has more features but the paint gets in the air passages really bad. The Graco and Apollos are bleeder types which means air blows thru the gun all the time. It actually helps to keep paint cleared from the air chambers. I have to say the Graco seems to be the best in the ones Ive tried. I have often wondered about the Fuji since it is so cheap. Tell me how it comes out ok? See ya !!
Ive been looking at them myself. I own a cheaper one but would like to up grade. I would checkout compliant spray equipment. They make / market accuspray or If I were going to buy a conversion gun I would go to homesteadfinishing.com Darkworksite4: When the job is to small for everyone else, Its just about right for me"
