Hydraulic cement
| Posted in Construction Techniques on November 11, 2003 07:16am
What is hydraulic cement?  What makes it different from regular cement?  Saw it mentioned in an article in JLC and realized I don’t know.
Do it right, or do it twice.
  1. BungalowJeff | Nov 11, 2003 08:41am | #1
    That's cement that can be applied/cured under water. Tremie concrete, some shotcrete mixes and wet-application patch materials (usually heavily modified with epoxy and other admixtures) are examples.
    ...that's not a mistake, it's rustic
  2. jimshome | Nov 11, 2003 08:42am | #2
    If you are referring to what I have used called hydraulic cement. It expands during curing. I've used it several times to plug cracks in basement walls.
    chisel out the loose cement so that it is slightly larger behind the crack than in front and press the hyd cement in hold pressure on it for a few minutes and presto no more leak!
     This above all, to thine own self be true, and it must follow as the night the day, Thou cans't not then be false to any man      Hamlet
  3. BobKovacs | Nov 11, 2003 02:26pm | #3
    You can buy it at HD or most mason suppliers.  As someone else said, it expands as it cures- good for setting wrought iron railings in concrete- just core a hole, set the rail in, and pour.  The expansion locks the rail in.
    Bob
Choosing a Paintbrush
  • The New Old Colonial
