Hydrondic heating w/ existing slab
bloomprojects | Posted in Energy, Heating & Insulation on March 31, 2008 02:11am
Basement remodel– I have an existing concrete slab and would like to install a hydronic heating system over it.  Many questions…. but do I need to insulate first?  How thick?  What is best- bed the PEX in concrete, gypcrete, or pre-made channel systems for the piping?  The finished floor will be carpet.
  1. Marson | Mar 31, 2008 03:11am | #1
    How much head room do you have? Insulation would sure be preferred if it is possible. As much as you can--two inches of xps would be good, but anything would help.
    As for the tubing, another option I have heard of is fastening sleepers to the slab, installing the tubing, and then putting sand in the space. Then plywood on the sleepers. I heard this from a mason who thought it was the preferred retrofit for in floor.
    1. dreadlock | Apr 01, 2008 04:32am | #2
      gypsolite is good consider other flooring because carpet will not let the heat through as much as tile or hardwood
  2. NRTRob | Apr 01, 2008 05:46am | #3
    where are you located, is the existing slab on grade or buried, and what's going over it?
    -=Northeast Radiant Technology=-
    Radiant Design, Consultation, Parts Supply
    http://www.NRTradiant.com
    1. bloomprojects | Apr 01, 2008 08:01pm | #4
      I'm in Seattle.  The slab is on grade and the finished floor will be carpet over pad.  I think I need to install 2 inches of insulation, then gypcrete or lightweight concrete with Pex imbedded, then pad/carpet.  The trouble is I then lose 4 inches of height... which I'd rather not.  Any ideas?  I hear the existing slab will suck the heat down, thus the insulation requirement.  I also hear the carpet/pad reduces the effectiveness of the hydronic system.
