I am considering running hydronic heat under my bedroom floor. the floor is approx 14×29 feet, and is supported by 5×9 inch gluelams. The beams are covered by 1.5 inches of OSB. I am going to cover the OSB with carpet.
I was considering running 1/2 inch copper tubing under the floor.
Any suggestions?
Prescriptive codes don't address the connection at less common angles, so base the connection off more typical ones using bolts, structural screws, blocking, and steel tension ties.
Sounds expensive, try PEX tubing
I am considering running hydronic heat under my bedroom floor. the floor is approx 14x29 feet, and is supported by 5x9 inch gluelams. The beams are covered by 1.5 inches of OSB. I am going to cover the OSB with carpet.
Any suggestions?
