Hydronic Heat Under Wood Subfoor
| Posted in Energy, Heating & Insulation on October 26, 2002 08:37am
Does anyone have experience with hydronic heating under subfloor and carpet?  I am building an addition and plan to heat with hydronic tubing under 3/4 OSB subfloor with carpet over that.  I know that doesn’t give me the benefit of mass like concrete but it seems like a better option than hot water baseboards.  My heating contractor suggests creating an airspace around the tubing by spacing the insulation down from the floor  1-1/2″ thereby allowing the heat to move up through the floor. The exsisting house is in-slab radiant heat.  Any thoughts or recommendations would be helpful.
  1. MJLonigro | Oct 26, 2002 05:20pm | #1
    Haven't tried this yet but a HVAC contractor on my job says to use the subfloor that has the grooves cut for the PEX tubing with the aluminum baffles already installed, followed by a layer of Wonderboard (cement backer board) over it, then whatever flooring material you want...
    Sounds like a good solution but I have yet to try it.
    Re: in slab radiant heat. Is it  bare copper tubing? If so, get the jack-hammer out.
    Another co-worker just purchased a house with in slab bare copper tubing and surprise, surprise, it's leaking like a sieve....He's spending the next few weekends re-piping his house.
