I have metal beams that are 4″ width, the metal studs are 3⅝ wide.
![](https://secure.gravatar.com/avatar/2672982d58a0a094f0520360e443adce?s=52&d=https%3A%2F%2Fimages.finehomebuilding.com%2Fapp%2Favatars%2F200x200%2Fe.png&r=g)
I will be installing PVC wall panels, in order to keep the wall flush what’s the best option? I’ve surmised the only way to solve this is by putting studs on top of these studs, probably 2″ wide, but that’s more money than I wanted to spend, not to mention a little less space inside the room.
In the picture: the angle iron will be cut flush, just haven’t got there yet.
Any advice is greatly appreciated.
I’m having trouble understanding.
Please explain the situation and either add a picture or tell me what I’m looking at.
Thanks.
The inside of a barndominium. There is a coat of thick spray foam insulation covering the the metal panels and most of the angle iron. The cylinder beam is one of 6, 4 of which are in the corners and won't be an issue when framing as they are recessed. There is a piece of angle iron protruding out attached to the cylinder beam that will be cut back eventually. This building was not built by myself and is inherited as is from the previous owners.
Answer me this.
Are you framing walls using 3-5/8” metal studs and then fastening pvc panels to the metal studs?
There are 4” metal studs or you can stand off the walls and still use the 3-5/8 . If you expect movement in height you can use deep throat channel and not fasten the stud to the top track.
Bracing mid height can be achieved using resilient channel.
Am I close in answering your question?
Those wall panels, PVC or fiber reinforced plastic (FRP) are designed to be adhered to a flat substrate, either drywall or plywood.
It may end up less expensive to just install drywall (over a suitable non-load bearing framing structure, either metal or wood) and finish than to use the panels.
If your panels are not meant to be adhered, they still need support.
for example,
https://farmerboyag.com/trusscore-wall-and-ceiling-panel-8-ft-l-x-16-in-w-x-1-2-in-thk-pvc
needs support at each edge.
