I hear voices…
stikineriver | Posted in Energy, Heating & Insulation on May 11, 2002 10:20am
I just completed the installation of a HRV system in a new house. The bedrooms all have supply ducting feeding air to the rooms via a 6″ round duct in the attic. Now we went to great lenghts to make the rooms as sound proof as possible with stagger stud walls and wall deading insulation. Now the problem, my clients can hear everthing that there teenage daughters say in their rooms and I guess the daughters can hear all that goes on in the master bedroom. Question? Is there a sound baffle of some sort that can be installed in the duct to prevent this sound???
  1. DavidThomas | May 12, 2002 04:22am | #1
    Obviously a quick trip to a culture where 4 generations eat, sleep, have sex, etc. all in a one room house would be the easy (for you) fix. :-)
    Consider a car mufffler. It greatly reduces the noise transmitted in air through metal pipe. A similiar arrangement in the ductwork will help a lot. You want to reduce line-of-sight or single-bounce paths between people having sex (parents or teenager) and those listening (teenager or parents, respectively). Sound absorbing material (acoustical foam or even carpet) on the interior will help a lot. The duct work functions so well as a "wave-guide" because shallow-angle sound gets a good bounce off the metal. Force it to do some 180-degree bounces (the more the better) and consider covering those surface with acoutisically "dead" (not hard) materials. Good Luck.
    David Thomas   Overlooking Cook Inlet in Kenai, Alaska
    1. stikineriver | May 12, 2002 04:36am | #2
      Thanks for the advise David. I don't think my clents want to go back to the cave man days! John Taylor, Wrangell, Alaska
Fast, Accurate Wall Framing
