I-joists and their use as rafters
teewhite7 | Posted in General Discussion on October 19, 2020 11:47pm
Okay so I’ve been researching some options for ridge beam straps/brackets and hurricane ties for rafters (to place into a drawing detail) and I found a few helpful dwg files on simpsons website. My question is, in my search for rafter to ridge and rafter to plate fasteners it looks like everything is detailed using I-joists in the place of rafters. Is this the standard now? I’m a little lost with this, they’re called I-joists for a reason I assumed. Why does every detail simpson has involving rafters have an I-joist in place of rafters?
    unclemike42 | Oct 20, 2020 07:53am | #1
    Editorial choices for the Simpson website may get a better response by contacting them.
    The products shown in drawings which feature I joists are designed to work with them.
    The engineering has to be different (hole locactions....fastener use....) than products intended only for use with solid lumber.
  2. catmandeux | Oct 20, 2020 09:10am | #2
    https://www.strongtie.com/search?v=%3Adrawing-name-asc%3AdrawingProductLine%3AWood+Construction+Connectors%3AdrawingDimension%3AHigh+Wind-Resistant+Construction+Details%3AdrawingFileType%3APDF&tab=drawing
    1. mgmahan | Oct 20, 2020 10:52am | #3
      This page shows details for solid sawn lumber and for trusses. Not just I-joists.
      1. teewhite7 | Oct 27, 2020 10:05am | #7
        Hey thanks, but a link may not be showing in your comment
    unclemike42 | Oct 20, 2020 02:03pm | #4
    It is not uncommon for rafters to be built from solid lumber, from I joists, or to frame roof supports using engineered roof trusses of various designs.
    As you may have guessed, they are called I joists because in cross section they resemble a capital I (in fonts which include a horizontal line top and bottom, anyway....)
    Similar to nomenclature of steel I beams.
    1. teewhite7 | Oct 27, 2020 10:03am | #6
      Forgive me, what i meant was - I assume they're called I-joists for a reason - and not "I-Rafters" lol.
  4. WISteve | Oct 20, 2020 06:15pm | #5
    These particular brackets and straps were created because the use of I-joists as rafters predicated the need for them.
    Solid lumber, historically, has had other options for fastening.
  5. teewhite7 | Oct 27, 2020 10:14am | #8
    Thanks everyone, i guess what I'm having trouble finding is reference material, for standard stick framing. which is literally the only method i have ever seen f/ residential.
    So as you could imagine, digging for reference material and EVERYTHING i see is NOT stick framing, i figured the best place could be simpson with their wide range. But everything is engineered materials (trusses, I-joists, etc).
