I need a hard prefinished hardwwod floor
Portland | Posted in General Discussion on February 11, 2005 01:53am
Does anybody have any experience with pre-finished hardwood flooring? I’ve typically installed traditional hardwoods and was thinking of using the prefinished products. I’me concerned about the product, because I have a relative in the building business that installed quite a bit of a prefinihsed product and it turned out to be too soft. Can someone recommend a “Hard” prefinished hardwood product? Thanks
  1. HomeCPR | Feb 11, 2005 02:12am | #1
    Tom
    I do not know about the "hardness" of the floor; but the Kahr's wood floors install nice and lock together very tight and look great when you are done.
    Paul
    1. Portland | Feb 12, 2005 06:26am | #2
      Thanks, I'll look it up. T
        BillHartmann | Feb 12, 2005 09:53pm | #5
        Are you talking about the hardness of the finish or the hardness of the wood?
        1. Portland | Feb 13, 2005 01:18am | #6
          I'm looking for a hard wood, that is one that will resist the day to day denting of a kitchen, and shoe traffic.
          1. IanDG | Feb 13, 2005 01:40am | #7
            Brazilian Cherry, Brazilian Teak -- both of these are harder than oak.
            IanDG
          2. Portland | Feb 14, 2005 08:22pm | #10
            Thanks. Tom
          3. jetlag | Feb 14, 2005 08:34pm | #11
            If you're interested in Brazilian cherry or other exotics, I can get them for you really inexpensively.
          4. Portland | Feb 14, 2005 09:14pm | #12
            Thanks for the offer, but were not to that point yet. Tom
          5. HARDWOODGUY | Feb 15, 2005 03:42pm | #13
            "I'm looking for a hard wood, that is one that will resist the day to day denting of a kitchen, and shoe traffic."Resist? It won't happen. Sure some of the harder species such as Brazilian Walunt and Brazilian Teak won't show indentations as much as an American cherry, but they will show indentations, and scratching. Preventive maintenance is the key. Any hardwood floors will scratch and ding regardless of the hardness. Frankly I wouldn't suggest hardwood floors for kitchen use unless you're determined and have a careful household. Hand scraped or distressed products may provide an answer.
          6. Portland | Feb 15, 2005 10:15pm | #18
            Thanks for the information. How about pre-finished materials. Are the laminated products any better? Tom
          7. User avater
            BillHartmann | Feb 13, 2005 01:40am | #8
            Here is a chart of hardness for different spieces.http://www.hardwoodinstaller.com/hardwoodinstaller/hardness.htmAmong the common ones white oak, ash and hard maple are fairly hard.Some harder ones are hickory/pecan.Then you have the exotics that are very hard such as the Brazilan cherry.
          8. Portland | Feb 14, 2005 08:21pm | #9
            Thank you for the information. Tom
    JeffBuck | Feb 12, 2005 07:48am | #3
    the hardness or softness can depend on the wood species.
      Buck Construction
       Artistry in Carpentry
            Pgh, PA
  3. DThompson | Feb 12, 2005 08:57pm | #4
    Vintage Pioneered solid hardwood flooring, http://www.vintageflooring.com out of Toronto, Canada sent me are real nice sample and display package for their product.
    johnnyd | Feb 15, 2005 05:23pm | #14
    I recently used "Bruce" pre-finished maple on my kitchen/dining room floor.  The maple is plenty hard to resist dents, and the pre-finish is really hard.  There are many posts and threads on this subject in the archives...try a search.
    I believe that even the pros will occasionally recommend a quality pre-finished flooring with the main benefit to the pre-finish being that it is applied in a factory controlled manner with consistent temperatures etc.  Also, in the factory, they can use much more poisenous products and vapors, as opposed to an on-site situation where both the applicator and the occupant have much more exposure to the finishing fumes.
    End result being a much more durable finish.
    The major drawback to prefinished flooring is that, by definition, since the strips will NOT be sanded smooth after fastening down and then finished in place, there will be a slight bevel or champfer on the edge of each board to hide the slight irregularities that are inevitable when nailing flooring down.  Results are that when you look accross the pre-finished floor you will see each individual board.  Dead giveaway.  To some this is objectionable, to others (me included) this failing is made up for by the facts that:
    1...you can start living on the floor as soon as it is nailed down
    2...the finish is probably harder and more durable than any finish that could be laid down in place.
    1. BSayer | Feb 15, 2005 08:42pm | #15
      I agree - I don't like the look of the 'micro-bevel' that is on pre-finished floors.Yellow pine is another very hard wood. Old growth from a reclamation place makes for a very nice looking floor. It will have areas of reddish brown and areas of yellow. Lacquer sealer smoothes out the color differences slightly, but still leaves enough variation to be interesting.
    2. Portland | Feb 15, 2005 10:19pm | #19
      Thank you for the input. We were considering the pre-finihsed flooring because the time to install and finish traditional flooring was an issue. The extra week to ten days would have added up to a lot of carry cost on this project. Warranty issues were a positive with the pre finised. I'd heard good things about the Bruce Wear Master product and have looked at it. Thanks Again.
    JeffBuck | Feb 15, 2005 09:49pm | #16
    check out
    http://www.br111.com
    Their products are about the best I've ever installed.
    the installation for for customer supplied materials ... and he researched everything to death .... he wanted the "best of the best" as far as this remodel went ... so I trusted his judgement and found out that once again he was right.
    It as absolutely great stuff to work with.
      Buck Construction
            Pgh, PA
    1. Portland | Feb 15, 2005 10:24pm | #20
      Thanks from the Left coast. I looked at the web site and will include their products in our final list. Tom
      Edited 2/15/2005 2:29 pm ET by Tom
    2. Darin | May 23, 2005 09:54pm | #22
      Jeff,
      What product did you use, the engineered flooring or the pre-finihsed 3/4 in flooring?
        JeffBuck | May 24, 2005 12:21am | #23
        I had to go back thru their site to remember ...
        it was 5/16th thick ... I believe what they call BR111 Engineered.
        Looked to be "all real wood" ... but I think they glue the face wood over something more stable. It was the 6 1/4 wide planks .... think they ran right at 4ft long.
        I was very impressed with their milling/tolerences. Virtually no waste due to unusable planks. It was a floating/edge glue floor ... so straight/square planks were needed.
        Still used my strap clamps ... but didn't have to "force" any that I can recall.
  6. bigman | Feb 15, 2005 09:51pm | #17
    Take a look at the commercial grade Harris-Tarket prefinished flooring. I' ve seen it used on furniture store showrooms and the stuff takes quite a beating, plus the veneer is almost 1/8" so you can sand and refinish. it comes in 7" x 7' T&G panels and does not have a beveled edge.
    1. Portland | Feb 15, 2005 10:29pm | #21
      I appreciate your input, especially because you have used it in commrecial applications where the traffic is more likely to be heavy. I'll check out their web site today. Tom
Mortar for Old Masonry
