I recently came across an article in the local paper about a certain brand of OSB that had some manufacturing defect. I can’t remember exactly what the problem was or who the manufacturer was. If you know anything about this I would appreciate the info.
The most common way to make your own parging mix is to use either Type S mortar for block or Type N for brick and add a concrete bonding additive.
I recently came across an article in the local paper about a certain brand of OSB that had some manufacturing defect. I can't remember exactly what the problem was or who the manufacturer was. If you know anything about this I would appreciate the info.
