Currently remodeling a 1965 vintage colonial in New England with fiberglass batte insulation. The house feels very drafty. Can Icynene insulation be injected into outside wall cavities to add additional insulation as well as seal the house, or do I have to rip out the old fiberglass battes? What are other alternatives for sealing house as well as increasing insulation?
Listeners write in about deepening foundations and ask questions about HRVs, smoothing rough concrete, and finding the right workwear.
How to Install Exterior Window TrimRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
Tosh , All of the icynene I have seen applied has been spray-on app.
*I recall reading somewhere that they had a new product that could be injected into wall cavities(as opposed to surface spraying) but I wasn't sure what the success rate was with this type of application. Thanks, though, for your input
*I believe they do have an injectable foam, but you already have fiberglass in your wall cavities. Adding the foam might blow out your walls, so you'd need to remove the FG first.did
