Does anyone have a recommended method for removing the chalked paint that has washed down from aluminum siding/shutters onto the brick below?? Will TSP and a pressure washer do it, or is there a better chemical/method? Thanks!
Does drilling new screws into the roof rafters compromise the strength of the roof?
Check with a local (good) brick supplier/block yard or maybe even a concrete supplier. They hopefully will have available a graffiti remover that can do the job and not discolor the brick. If you need a name of a product, email me and I'll make a call.
