Ideas to fix wobbly stair railing.
madmadscientist | Posted in Construction Techniques on October 19, 2005 01:28am
Hello Folks,
  I an elderly neighbor lady of mine has a horribly wobbly stair rail leading up to her front door.  She says that a couple of crackheads got into a fight on her steps and after that the railing was loose.  I looked at it and this is what I saw.  She has cement steps leading up to her front door with ‘wrought iron’ stair railings on both sides.  The railing is supported with three vertical square metal posts at the top middle and bottom.  The posts appear to be sunk right into the concrete of the steps. The crackheads managed to break out the concrete around the posts-well not really break it out just loosen it up and create a bigger hole that the post flops around in.
  It gives me heart palpitations watching her and her elderly friends climb those steps and use that rail (and these are the type of folks that need handrails).  The steps are not that old so I am surprised that the crackheads were able to work the posts loose.  Does anybody know of a way that I can ‘shore up’ this rail?
  What if I cleaned out the enlarged holes and filled them with anchor bolt epoxy?  Or I  could weld large L brackets near the bottoms and sink new bolts in?  She won’t let me do it for her for free but I did bargain her down to just paying for the materials (or some portion there of if I can sneak it past her) so a materials thrifty but more labor intensive idea would not be bad.
  Thanks,
Daniel Neuman
Oakland CA
Crazy Home Owner
  1. Piffin | Oct 19, 2005 01:41am | #1
    Simpson Strong-tie has an epoxy that will fit into a regular caulking gun that would be perfect for this. At room temp, or a bit less it will cure in 20 minutes to an hour. If you can't find it out there, I might have a kit I can send you.
      madmadscientist | Oct 19, 2005 02:44am | #3
      Hello Piffin,
      Was this the stuff you were thinking of?
      http://www.simpsonanchors.com/catalog/adhesives/at/index.html
       Daniel Neuman
      Oakland CA
      Crazy Home Owner
      1. Piffin | Oct 19, 2005 03:49am | #4
        yes, the one they call fast pak is the one that fits in a standard caulking gun. The others require a special proprietary gun to push and mix, but they hold a lot more and cost more. For a one-off job likle yours, this is fine. it really is strong, but try to blow the dust out before pumping this in
  2. Pierre1 | Oct 19, 2005 01:44am | #2
    In the old days, pouring hot lead around the posts would have been the ticket. Nowadays, your epoxy idea sounds good.
    costofwar.com/
  3. slykarma | Oct 19, 2005 04:06am | #5
    Piffin has steered you right. The Simpson epoxy works fine although it is expensive for the volume you get, but for occasional use it's fine,  and not having to buy a proprietary gun balances the situation.
    A couple of things to note:
    • good cleanout is essential for epoxy application, dust in the hole can make the bond fail. Blow it out thoroughly with a compressor if possible.
    • have everything ready to go before mixing the epoxy because this stuff doesn't have a long working time - 10 minutes at best, less if it's warm out.  If you need to brace the posts until the adhesive sets up, have those planned and ready to go.
    • give the caulking gun a few squeezes to get the parts mixing and then dispense some out onto scrap plywood or cardboard or whatever - don't use the first few squirts until the stuff coming out of the nozzle is a uniform grey colour. That's how you can tell it's properly mixed and will achieve full strength.
    Good luck, and good for you. You are a good neighbour.
    Lignum est bonum.
      madmadscientist | Oct 19, 2005 08:53pm | #6
      Thanks for the help guys this seems like it should be an easy and not so expensive repair.  I have a 7 gallon air tank that I will take over there to blow out the holes with.
       Daniel Neuman
      Oakland CA
      Crazy Home Owner
      1. foobytor | Oct 19, 2005 10:52pm | #7
        The simpson epoxy we have here has an integral stirrer spun w/ yr drill and then ye just pumps it into the holes as if it were caulk in a gun. Has great strength to it.
Picture-Perfect Pergola
