I’m done with screws – now STEEL VELCRO!
http://www.newscientist.com/article/dn17739-extreme-steel-velcro-takes-a-35tonne-load.html
Velcro made of steel that hold 35 tons up to 800 degrees. I see a new shingling fastener!
Tu stultus es
Also a CRX fanatic!
Look, just send me to my drawer. This whole talking-to-you thing is like double punishment.
35 tons / square meter = ~45 lbs per square inch @ 800 degrees
Impressive. I wonder how the steel Velcro gets attached.
>>I'm done with screws ....I see a new shingling fastener!<<
You screw down your shingles?
Oh, must be those 1-1/4" GRK cabinet screws with the washer heads and Climatek coating..... ;^)
Jim
several of the old barns around here have shingles put on with wooden pegs. Still in place when the foundation or timbers rotted out. Over 100 years later!
I wouldn't even want to think about the time that took.
>>...... shingles put on with wooden pegs.....<<
It obviously worked!
I might have a hard time selling the technique, first to the customer, then the BI.......
There is a old, very exclusive, country club here with a hardwood ball room floor which is fastened with "butteryfly biscuits". Flooring is about 6" wide --- thousands and thousands of hand cut joints to accept the biscuits, ~24" apart on edges plus one at each butt joint......
I don't know the proper name of the joinery technique. The biscuits look like a butterfly or back to back dovetail.
Flooring is maple, biscuits are mahogany. When you walk across the floor it has a slight "hollow" sound - I get the impression it is one of the original floating floors.
Beautiful.
Same country club has a roof which is covered in 1" inch thick slate - still planar as can be - I always wanted to go into the attic to see the framing underneath of that!
Jim Never underestimate the value of a sharp pencil or good light.
Of course, the Velcro adhesive will give way long before that load is reached, unless you attach the steel Velcro with steel screws.
