I’m looking to build a flat sliding door, what materials should I use?
countrygirl360 | Posted in General Discussion on February 20, 2015 02:27am
What are the best materials to create a flat, quiet, sliding door that I can use for noise reduction?  Its 8 ft tall and one side faces the laundry room, that wont warp.  I dont want the wood to bend due to heat & moisture changes.
  1. DanH | Feb 20, 2015 06:31pm | #1
    Plain old 3/4" plywood should
    Plain old 3/4" plywood should work pretty well.  You can get hardwood faced plywood both to look nice and because it generally has more laminations and will stay flatter.  But varnish well to help it say flat.
    Otherwise, a sheet of cement board would work, but heavy and ugly.
  2. mark122 | Feb 23, 2015 10:22pm | #2
    can you order a door?
    if you cant order a door or you are determined to build one, i would at least use 6/4 rails and stiles and same species for the panels.
