Impulse Nailer & Senco nails
fishslayer7 | Posted in Tools for Home Building on April 19, 2007 04:54am
Greetings,
Looking at the Paslode Impulse Framer.
I have numerous Senco nailers and God knows Senco nails
coming out of my ears.  Will the impulse shoot the full round head
Senco nails?  Can’t seem to get a straight answer from anyone around here.
Fishslayer7
  1. Steddy | Apr 19, 2007 10:37am | #1
    30 degrees? paper tape or wire weld?
    i think it's grip rite marketing their clipped heads as compatible with the paslode now, btw.
    i think you might be asking for it. back when i was a youngster with my paslode under warranty, i put a clip of plastic collated nails in and broke the driver blade on about the 5th shot i think. i'm sure it could have been several diffent reasons, but i won't do it again.
    call your local paslode repair place and ask what they think - they should have a good familiarity with nailer mechanics and the possibilities.
  2. mvflaim | Apr 27, 2007 09:32pm | #2
    If you own an Impulse IM325 then yes, Senco framing nails will work. A lot of dealers will stock both Senco and Paslode nails simply because they're interchangable and if they run out of stock of Paslode they can sell Senco.
    Gunner | Apr 27, 2007 10:29pm | #3
       Put some in and try it.
        Who dares, wins.
    http://thewoodwhisperer.com/
  4. rez | Apr 28, 2007 06:19am | #4
    The Impulse is a fairly expensive delicate machine. Not really a production machine like in sheathing procedures.
    Tho' Senco's might work in there I'd advise staying solely with Paslode products.
    Could cause unnatural wear for saving minimal costs. Not worth the risk on this machine.
    If you're planning on pushing that many nails thru it maybe a different gun would better suit the need.
    of course that's just IMHO you understand
    However, if one designs to construct a dwelling-house, it behooves him to exercise a little Yankee shrewdness, lest after all he find himself in a workhouse, a labyrinth without a clue, a museum, an almshouse, a prison, or a splendid mausoleum instead.
    Parolee # 53804
Fast, Accurate Wall Framing
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
