i plan on mortaring down” quarryed stone” in front of fireplace as a floor..plan on cutting out xsisting wood floor and then? backer board?glue screws?
Metabo HPT's dual-powered plunge router offers the option to plug in an otherwise-battery-operated tool for production work.
hawk
This stone is more than tile, will the floor system handle the added weight?
stone floor
yep ,floor system will handle the weight. firplace has a wood stove set out 18"from the center of the fireplace .surrounded by brick on 3 sides.backside and sides. the stone I wish to put in will be in front of the stove,about 50 square '
Is the fireplace already there and does it have a hearth?
If no hearth existing, this gets complicated. There MUST be a fireproof hearth extending 18" in front and 12" toeach side of the FP openning. Quarry tile over a wood framed floor system does not constitute a fireproof hearth, only a fireproof surface.
If this is merely decorative for a gas FP, then you are OK, depending on what structure there is to support the weight. What framing system and what subfloor material is there under the proposed ?
stone floor
thanks for the reply. there is a wood stove set out 18" from center of fireplace surrounded by a brick floor on 3 sides,back n sides. the stone will be in front of the stove aprx. 50 square '.subfloor is plywood n the floor system is all set to handle the weight.
