Can you recommend an infrared thermometer to use on cast-iron cookware? I don’t need one good enough for engineering applications–it just has to be accurate from 325°F to 550°F.
Janet
Janet
Dehumidification is listed as a selling point for HPWHs, but are they actually effective at lowering humidity?
The problem is finding something that can read that high. I have a ThermoHAWK, but it only goes up to 428F.
I have a raytek
I bought a raytek of amazon I don't know how high it goes, but I think at least that. It is the exact same thing as fluke except half the money.
http://www.amazon.com/Raytek-MT6-Non-contact-MiniTemp-Thermometer/dp/B000O80B5M/ref=sr_1_sc_1?ie=UTF8&qid=1341110204&sr=8-1-spell&keywords=raytech+infared+themoter
Will
I use this:
http://www.harborfreight.com/non-contact-laser-thermometer-96451.html
Only $40 at the moment, and some magazines have a 20% off coupon in the back.
What applications?
I'll be using the thermometer with a stovetop wafflemaker. It's hard to tell when the temperature is correct (although it turns out that incorrectly cooked waffles are highly edible). While I saved a lot by buying a stovetop iron instead of an electric, buying an infrared thermometer just for waffles still seems a bit extravagant. I could use some arguments in favor of having one in the toolbox.
Assuming that you don't need it for making Liège waffles, where do you get the most use out of your infrared thermometer?
Janet
I use it too:
Make sure the frying oil is up to temp
Check the water temp of the fish tank
Check the temp of the hot water heater
Find hot/cold spots in insulation
Have the kitty chase the laser dot
Daughter used it as part of her science exparament on combustion
It was having the kitty chase the laser dot into a hot frying pan.
Aha, a Hunger Games event.
Janet
No competition - just for fun.
She wanted to see how environment affects how charcoal burns.
She lit 12 briquettes and then placed 4 in each environment: Soil, Sand, water (1/8" deep), and air (layed on suspended mesh screen).
We used the thermometer to check and see if the coals were still lit, as just sticking your finger into the ash isn't the brightest idea according to my wife <eyeroll>
Dear Daughter had great joy in using the instant on blowtorch we bought just for this! YAY FIRE!
