I have what appears to be a brass drainage system that goes from the house to the sewer line. Is it within the plumbing code to make an in ground repair? Is a no-Hub connector the way to do it?
thanks, Charles
thanks, Charles
Listeners write in about changing careers and organizing volunteer builders and ask questions about high humidity, underfloor cooling, and removing ceiling texture.
thanks, Charles
If it is indeed brass, you might consider tearing it out selling the scrap metal and puting in a new pipe.
Seriously a no-hub can be used on brass. It is more likely cu DWV which can be sweated or repaired with a no-hub.
