Inside uninsulated room wall
user-7764336 | Posted in Energy, Heating & Insulation on January 11, 2021 12:02pm
I have a garage with attic access with a knee wall.  Right now it just has fiberglass in the bays – could I cover the attic side/exterior with something like Zip-R or some rigid foam?  I was going to put rigid foam in the joist bays as air sealing but figured I’d better do the entire wall.  I want to try and attempt to create a similar building envelope around the conditioned space so I was thinking an insulated sheating would be best.  It would also give a good backer to attach some junction boxes that were in the attic on the wall studs.  The previous homeowner installed some rigid foam XPS on the first floor but I don’t think they did a good job since that room is still freezing as well.
  1. 90skidcarpenter | Jan 11, 2021 01:39pm | #1
    check out matt risinger on the youtube. he does this type of stuff for cutting edge building technology almost every videos. his channel is called The Build Show.
    chrisjacksonbest | Jan 12, 2021 09:02am | #2
    You may add insulation to your walls without removing it by cutting holes into the siding. You can blow spray foam or cellulose into the walls from outside. Just cut a 1 inch to 2-inch hole between the studs at the top of the wall and then spray the insulation into the hole using a hose.
Mortar for Old Masonry
