install a cellar door inside a bulkhead
| Posted in General Discussion on September 23, 2001 12:37pm
my plan is to frame the opening in the foundation with 1×4 pt stock (the opening is only 6′ high). use a pre hung luan door cut to fit within the height restriction, add weather stripping to the jams, use foam insulation to fill all voids. will this significantly reduce cold air infiltration intothe cellar?
  1. harry_williams | Sep 23, 2001 12:37pm | #1
    my plan is to frame the opening in the foundation with 1x4 pt stock (the opening is only 6' high). use a pre hung luan door cut to fit within the height restriction, add weather stripping to the jams, use foam insulation to fill all voids. will this significantly reduce cold air infiltration intothe cellar?
  2. rez | Aug 08, 2009 06:53am | #2
    perhaps.
      IMERC | Aug 08, 2009 07:19am | #3
      till the the door turns to garbage...
      WOW!!! What a Ride!
      jonblakemore | Aug 09, 2009 04:06am | #4
      Are you searching the archives for old "bulkhead" threads?
      1. rez | Aug 09, 2009 04:23am | #5
        heh ya, need to build a bulkhead door and got to looking.
         Saw an old '99 thread that got me started and couldn't resist.
