Installing 6 mil poly vapor barrier
tom21769 | Posted in General Discussion on August 25, 2007 10:11am
I’m installing 6 mil poly sheeting as a vapor barrier over pine tongue and groove panelling in a timber frame structure. Plans call for lapping the sheets and sealing with acoustic sealant.
I’d never heard of acoustic sealant before. Cannot find it at local hardware/big box.
What kind of product am I looking for? A solvent-based synthetic rubber? How about the DAP “Sidewinder” product?
I suppose what I want is something very flexible that will move with the wood, and that will bond plastic to wood. What am I likely to find at a Lowes or Home Depot?
    Mongo | Aug 25, 2007 10:43pm | #1
    Owens Corning makes a product called Quiet Zone.
    Another one that's carried locally is called Noise Stop.
    There are several out there.
    Mongo
    1. bobtim | Aug 25, 2007 10:58pm | #2
      Black death
      Tremco
      Gonna be a huge mess your 1st time. Have ajug of paint thinner handy for clean-up.
      1. alrightythen | Aug 26, 2007 02:21am | #3
        "Black death"
        good....glad I not the only who has succumbed to the evil punishment of working with Accoustical seal. I'm sure somehwere on the tube in very fine print there must be a guarantee that you will get it on you no matter what.
            View Image                                          View Image
  2. fingersandtoes | Aug 26, 2007 02:24am | #4
    What Bobtit said. Black death indeed. The insulation subs like to use it to seal the 6 mil to the bottom plate, but I now insist they use tape. It is very similar to roofing goo. You will find it on everything and it is murder to get off.
  3. 5brown1 | Aug 26, 2007 05:27am | #5
    Permatite makes an acrylic sealant which will stick to polyethylene.
    I got it from McMaster Carr when I was trying to find something to seal poly to foam ICFs.
    It was about the only thing I could find that would stick to poly.
    I even called several adhesive companies and spoke to their specialists trying to find something.
    The acrylic sealant worked very well.
      Luka | Aug 26, 2007 06:58am | #7
      Name, give with the name of the stuff, already !;o)
      Yeh... That'll work.
      1. 5brown1 | Aug 26, 2007 03:53pm | #10
        I did - "Permatite Acrylic Sealant". Comes in 10 oz tubes.
        Edited 8/26/2007 8:54 am ET by 5brown1
          Luka | Aug 26, 2007 08:03pm | #12
          Thank you.Permatite is a brand, and acrylic sealant sounded like just a description. Usually there is a specific name and/or number involved.
          1. DanH | Aug 27, 2007 05:07am | #13
            http://www.permatite.com/seal.htm
    Luka | Aug 26, 2007 06:57am | #6
    Wait a minnit.
    You are installing plastic OVER tounge and groove pine panelling ???
    1. tom21769 | Aug 26, 2007 01:38pm | #8
      >>Wait a minnit.
      You are installing plastic OVER tounge and groove pine panelling ???Yes. It's a "wrap and strap" wall package over a timberframe. Frame[ then borate-treated 7/8" EW pine t&g OUTSIDE the frame (visible from interior)[ then 6 mil plastic[ then 3" faced polyiso foamboard inside blocking[ then straping and CVG cedar siding on the walls & 5/8" plywood + felt + metal (terne) on the roof.Plastic is there to prevent moisture drive into the wall from interior. Strapping forms a drainage plane behind the siding.My question was about properly installing the plastic at the edges and seams.
        SamT | Aug 26, 2007 03:46pm | #9
        If you go to the auto body repair industry, they use something that looks and sounds like "Black Death" only it comes in 1/2" wide roll$ with a backing tape, just like any double sided tape.They use it to tape the wind/noise plastic barrior to the car doors under the finish panel.Since you can apply it at the rate of beau coup feet per minute, and there is no cleanup, I imagine the labor savings would pay for the extra cost of the roll$.SamT
        Luka | Aug 26, 2007 07:56pm | #11
        Ah.Ok, carry on.;o)
