installing an acrylic bathtub
meadows | Posted in Construction Techniques on April 9, 2007 07:14am
We are installing an acrylic bathtub and would like to know if it is necessary to pour a concrete pad between the floor and bottom of the tub.
  1. calvin | Apr 09, 2007 07:29pm | #1
    In most cases it is necessary to support fully the bottom of the tub.  What you use under there is your choice-sand mix over concrete-you don't need stone aggregate.
    http://www.quittintime.com/
  2. dovetail97128 | Apr 09, 2007 09:07pm | #2
    meadows,
    That depends on the tub manufactures instructions for installations.
    some require it , some advise it be done, some don't want it .
    CapnMac | Apr 09, 2007 09:48pm | #3
    You ought to be able to find the installation destructions online to let you look up what is recommended.
    Some tubs definitely benefit from some drystack; others will be better off with an expanding foam (the space to fill will commend either low 0r regular expansion foam).
    Using the foam can (just can) help the tub seem more temperate (less too-cold in winter; less too-warm in summer.  Your conditions will vary depending on the floor type, construction, etc.
    Personally, I've never liked any "feel" of springiness in a tub; but that may be from remodeling a few out of rentals . . .
  4. rez | Apr 09, 2007 10:59pm | #4
    meadows-
    Placing a second floor tub I put a 3/4" cut to fit the bottom of the tub perimeter, placed a touch of plaster of paris on the ply and wedged it under the tub with wood stock.
    Quick and easy.
    is your tub on a first floor slab?
    be now where is DanH?
    Parolee # 53804
    Edited 4/9/2007 4:00 pm ET by rez
